Yuhe1229
Oct 27, 2020Follower
Unable to connect to 2.4 network
A couple months back I moved and rented a modem from Xfinity, when the bill was due, I decided to switch to this current router I was using a couple of months ago. I purchase this router a few years ...
Oct 27, 2020Guru - Experienced User
I wouldn't wait on customer service as they'll charge you more than its worth.
You have 2 options.
1. if you can log into the 5ghz, you can access the router and view/change the ssid.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
Option 2. You can factory reset it and start back at square 1.
Push and hold reset for 7-15 seconds while its powered on.
that gets you back to the default login to the gui
login: admin
password: password
Then you can setup whatever you want again.
manuals and install guides can be found here:
