SueWei
Feb 21, 2021Aspirant
Unable to connect to AC1200/EX6120 WiFi extender
Hello All,<br><br>I have recently configured my extender as I have changed to a new router. The extender seems to indicate that it is connected to the router however none of my devices are able to con...
Feb 21, 2021Guru - Experienced User
did you set it up using wps or using the installation wizard?
If you used wps, I'd recommend factory resetting the extender and reinstalling using the installation assistant.
SueWei
Feb 22, 2021Aspirant
Yes I have connected via wps. I have also reset the extender to factory setting before configuring. Sorry to ask but I have no idea how to install using installation assistant or web browser. How do I connect to the WiFi extender network when I can’t even get my device to connect to the extender?
- plemansFeb 22, 2021Guru - Experienced User
Try factory resetting again.
Push and hold reset for 7-15 seconds while the device is powered on.
Then try following the assistant.
How to Setup your WiFi Range Extender with NETGEAR Installation Assistant - YouTube
