peteglanton's avatar
peteglanton
Unable to Connect to Apartment internet due to previous router settings
I just bought a new R6400 router to replace a Linksys router that I was not happy with. I live in an apartment complex where the internet is provided, and I was able to configure the previous device ...
  • TheEther's avatar
    Sep 21, 2015
    On the R6400, you want to go to Basic > Internet. There is where you want to replicate the settings from your old router that govern the connection to the ISP.
    I can't help you with logging into your old router and navigating to the appropriate settings.
