TheBratwurst
Aug 25, 2015Aspirant
Unable to connect to the Router setup after changing IP & factory reset (WNDR3700v2)
Hi Everybody, I got a new internet provider today, so i had to change the settings of my Router. Therefore i changed the Router IP to 192.168.0.2 (following a tutorial online), but after that...
- Aug 26, 2015OK, well the rough process is as follows; 1. Log into the base router and find its DHCP server settings, set the DHCP range to end at some convenient address e.g. a range of 192.168.100.2 to 192.168.100.199 2. Connect to and log into the WNDR3700 3. Set all WiFi and other settings as desired, but don’t bother with any router related functions e.g. Port Forwarding 4. When you are happy with the settings go to the LAN Settings page 5. Set the router IP address to a convenient address on the same subnet as the base router e.g. 192.168.100.200, do not apply the setting yet. 6. On the same page disable the DHCP server and apply the setting, the configuring computer will now lose its connection to the ‘3700 7. Connect a LAN port of the ‘3700 to a LAN port of the base router, power cycle the ‘3700 8. Computers that now connect to the ‘3700 by wire or WiFi will now be allocated IP addresses by the base router 9. The ‘3700 can be accessed at http://192.168.100.200 10. If all goes well, log into the ‘3700 and in the Maintenance area save the current configuration to a file on the computer, just in case. Sorry if the formatting of this reply is one big block of text, it's a browser issue with the computer I'm using.
Babylon5
Aug 25, 2015NETGEAR Employee Retired
Can you post a link to the online tutorial please?
At the same time as changing the router LAN IP did you also disable the DHCP server? If so then until the router is also connected to another device that is operating as a DHCP server e.g. a modem/router combo, then any connected computer will not be allocated an IP address on the LAN and will not be able to communicate with the router.
TheBratwurst
Hey, thank you so much for your rapid answer!
The tutorial is in German, but it is also wrong, because the DHCP-aspect was not mentioned.
I was able to reset the Router now (i didn't press the button long enough, didn't know it's 7 seconds :smileylol: )
I also disconnected it from the Router of my new provider.
Now I'm in the setup again (IP is 192.168.1.1)
The Router of my Provider has the IP 192.186.100.1.
Now I want to set the IP of the Netgear Router to 192.186.100.10 (I already conected some Wifi devices to the Providers Router, so I'm not sure if 192.186.100.2 is free) and also turn that DHCP thing of. Is there anything else to do to be able to access to the internet again?
- TheBratwurstAug 25, 2015Aspirant
Okay i just disabled the DHCP server and set the Routers IP to 168.192.100.2.
Now, again, i can not interact with the Router and can't connect to the internet...
Any ideas someone? :(
- Babylon5Aug 26, 2015NETGEAR Employee Retired
I’m not completely sure what your intended setup is? The description you have given so far suggest that you are trying to set up the ‘3700 as an Access Point connected to an ISP supplied router, is that the case?
The 192.168.100.1 IP address is commonly used by DOCSIS cable modems, these can also be routers but are not always, what is the model number of your modem?
If your modem is not also a router then the ‘3700 should be set up in router mode. You can if you wish still change the LAN subnet of the ‘3700 to 192.168.100.x, but only if the modem it is connected to does not use that range (and it seems that it does), otherwise the ‘3700 is likely to automatically change its subnet to 10.0.0.x and this may have been your original issue that stopped the PC communicating.
Please answer the above first and then we can look at the best solution / setup.
- TheBratwurstAug 26, 2015Aspirant
Yes, thats is the case. The provider sent me a CBN-CH6640E modem, which is also a wifi-router. I want to set the '3700 as an Access Point to connect my devices in the upper floor via LAN and Wifi.
