TheBratwurst's avatar
TheBratwurst
Unable to connect to the Router setup after changing IP & factory reset (WNDR3700v2)
Hi Everybody,   I got a new internet provider today, so i had to change the settings of my Router.   Therefore i changed the Router IP to 192.168.0.2 (following a tutorial online), but after that...
  • Babylon5's avatar
    Babylon5
    Aug 26, 2015
    OK, well the rough process is as follows; 1. Log into the base router and find its DHCP server settings, set the DHCP range to end at some convenient address e.g. a range of 192.168.100.2 to 192.168.100.199 2. Connect to and log into the WNDR3700 3. Set all WiFi and other settings as desired, but don’t bother with any router related functions e.g. Port Forwarding 4. When you are happy with the settings go to the LAN Settings page 5. Set the router IP address to a convenient address on the same subnet as the base router e.g. 192.168.100.200, do not apply the setting yet. 6. On the same page disable the DHCP server and apply the setting, the configuring computer will now lose its connection to the ‘3700 7. Connect a LAN port of the ‘3700 to a LAN port of the base router, power cycle the ‘3700 8. Computers that now connect to the ‘3700 by wire or WiFi will now be allocated IP addresses by the base router 9. The ‘3700 can be accessed at http://192.168.100.200 10. If all goes well, log into the ‘3700 and in the Maintenance area save the current configuration to a file on the computer, just in case. Sorry if the formatting of this reply is one big block of text, it's a browser issue with the computer I'm using.
