Habibulalam's avatar
Jun 08, 2016
Unable to Enable Access Point Mode
Hello sir, This is Md. Habibul Alam, from Dhaka, Bangladesh. I'm using Netgar R6220 Router. and i con't Enable Access Point Mode to make wireless Bridge at my Home.   Netgear R622 is my main route...
  • TheEther's avatar
    Jun 08, 2016
    In Netgear's terminology, Access Point mode is not the same as a wireless bridge.
    Access Point mode: Requires a wired connection to the main router.  Provides Wi-Fi and wired access to clients.
    Wireless bridge: Uses a wireless connection to the main router.  Provides wired access to clients.  Wi-Fi clients are NOT supported.
    The R6220 can be used as an Access Point.  It is enabled in ADVANCED > Advanced Setup > Wireless AP.  The R6220 cannot be used as a wireless bridge.
