Habibulalam
Jun 08, 2016Tutor
Unable to Enable Access Point Mode
Hello sir, This is Md. Habibul Alam, from Dhaka, Bangladesh. I'm using Netgar R6220 Router. and i con't Enable Access Point Mode to make wireless Bridge at my Home. Netgear R622 is my main route...
- Jun 08, 2016
In Netgear's terminology, Access Point mode is not the same as a wireless bridge.
Access Point mode: Requires a wired connection to the main router. Provides Wi-Fi and wired access to clients.
Wireless bridge: Uses a wireless connection to the main router. Provides wired access to clients. Wi-Fi clients are NOT supported.
The R6220 can be used as an Access Point. It is enabled in ADVANCED > Advanced Setup > Wireless AP. The R6220 cannot be used as a wireless bridge.
Habibulalam
Jun 14, 2016Tutor
is their any way to connect between netgear r6220 and tenda f303 wirlessly?
- HabibulalamJun 14, 2016Tutor
Thank you somuch, I did it successfull.
