PronessDave
Aug 30, 2021Aspirant
unable to get into my router settings
When i try to enter the router website, I get shown to NEW EXTENDER SETUP and i enter all the relevent information but nothing happens after i click next. It just doesn't respond. How do i get past t...
- Sep 02, 2021
I fixed the problem. I had an idea of just factory resetting the router and now it works. Thanks for your time plemans michaelkenward
Aug 30, 2021Guru - Experienced User
Sounds like you're trying to connect to the extender.
are you trying to access the router using the routers IP address?
Did the extender setup fine?
Have you tried a different browser? Pc?
- PronessDaveAug 30, 2021Aspirant
Tried using different different browser and still doesn't work. Tried entering my default extender IP address and it displays "Took too long to respond".
- plemansAug 31, 2021Guru - Experienced User
the default IP address will change based on your router.
Log into your router and lookup what IP address the extender is connecting on.
Use that to try to access it.
- PronessDaveAug 31, 2021Aspirant
Found my extenders IP address which took me to create an account again. Nothing happens when clicking NEXT. The photo doesn't show it but i did fill in all those boxes before clicking NEXT.
