PronessDave
Aug 30, 2021Aspirant
unable to get into my router settings
When i try to enter the router website, I get shown to NEW EXTENDER SETUP and i enter all the relevent information but nothing happens after i click next. It just doesn't respond. How do i get past t...
- Sep 02, 2021
I fixed the problem. I had an idea of just factory resetting the router and now it works. Thanks for your time plemans michaelkenward
michaelkenward
Sep 02, 2021Guru - Experienced User
If you reset the device, you will have to set it up again. Then there should be a way to bypass any "wizards" that try to help you to set up the device.
According to the manual (page 74) there should be an option to CONFIGURE MANUALLY.
Did you check the appropriate section for the EX6200:
WiFi Range Extenders & Nighthawk Mesh
I can see a few questions there on the same lines.
PronessDave
Sep 02, 2021Aspirant
- michaelkenwardSep 02, 2021Guru - Experienced User
Glad it worked. As I suggested, a reset is often a good way out of those login issues.
Now that you have access, you can decide whether or not to enable password recovery.
And when the thing is set up to your satisfaction, it is a good idea to save a copy of your configuration. You can then reload that if you ever have to reset the thing again.
