kaboomsmom's avatar
kaboomsmom
Unable to get updated firmware ver 1.0.0.42 into the WNR2000v5 router, N300 WiFi router
I've done the following, after extracting the file, which is: WNR2000v5-V1.0.0.42.img and was extracted to my hard drive PC running Windows 7) as well I placed it onto my desktop so it's easy to get to. My WNR2000v5 is currently at ver 1.0.0.34
****Until I get to here (Below):  I do not see a Browse tab or or field or ?. Where do I go to see/choose Browse?  I've also tried to update the router's firmware by using NetGear Genie, again, failed to upgrade "Failed to get firmware version information"
  • Click Browse and find the file you just downloaded.
  • Click Upload. Do not interrupt the upgrade while the router does this step.
I also tried getting into the router via the Browser and using the Firware Upgrade Assistant. Just sits and spins endlessly, saying: "Please wait a moment" are 30 minutes too long to wait? UG!
How the heck can I get this into my router? I've tried this multiple times. This is the most difficult, convoluted firmware update I've ever encountered.
Please help,
Cindy
o
  • I finally got the download done. It was the adaware program interfering with the download. Thank you for your response...
    Cindy
