jmclh
Jul 06, 2020Aspirant
unable to install firmware hotfix
D6220 Firmware Version 1.0.0.56 - Hot Fix I am trying to install this security hotfix but the downloaded zip file, when opened produces a file name ending in .chk. When I try to upload this in the r...
- Jul 06, 2020
> I am trying to install this security hotfix [...]Onto _what_, exactly? Look for "Model" on the product label.
> Model: D6200|Dual Band 11ac ADSL Modem Router
"D6200" and "D6220" are spelled differently for a reason. The D6200
seems to use a ".img" file; the D6220, a ".chk" file.> [...] When I try to upload this in the router's gui it gives an error
> message saying the fiename is invalid and should end with *.img. [...]Loading a firmware image for the right device might help some.
antinode
Jul 06, 2020Guru
