MBfromOK
Jun 23, 2021Aspirant
Unable to load new firmware on R6300v2
My Router (1.0.4.2) is reporting a new version is available (1.0.4.46_10.0.93) but it fails to download the file internally... When I went to the Netgear download site and chose my model it shows th...
Jun 23, 2021Guru - Experienced User
prior to uploading it, did you extract the download?
right click on the file you download (if on windows) and extract it.
Then try it.
- MBfromOKJun 27, 2021Aspirant
Indeed, I extracted it before trying to apply... Previous to extracting I tried to apply it as a .zip and it returned a "not a .chk file" error.
- antinodeJun 27, 2021Guru
> This firmware file is incorrect! [...]
What is the name of that "incorrect!" "firmware file"?
> [...] Previous to extracting I tried to apply it as a .zip and it
> returned a "not a .chk file" error.As it should have.
If you really do have an R6300v2, and you're really specifying a file
like "R6300v2-V1.0.4.52_10.0.93.chk", and the router hates it, then I'd
try a smaller jump. "1.0.4.2" to "1.0.4.52" in one step might be too
far. It's unusual, but such things have been reported.- MBfromOKJun 28, 2021Aspirant
I tried:
- R6300v2-V1.0.4.46_10.0.93.chk
and:
- R6300v2-V1.0.4.52_10.0.93.chk
I will try to locate, download, and apply an upgrade file closer to 1.0.4.2.. will let you know!
