stanbray
Sep 25, 2019Tutor
Unable to log in to WAC720 after firmware update
Just updated my WAC720 firmware from 3.6.12.0 to 3.9.1.0 and when I enter the correct user name and password on the web login, the login screen reloads with no error. I can log in via SSH, but I do ...
- Nov 18, 2019
Found this thread yesterday: https://community.netgear.com/t5/Business-Wireless/WAC730-Can-t-get-past-login-after-firmaware-upgrade-3-9-1-0/td-p/1794498.
The problem is that Netgear changed the password requirements without notice in this firmware version. You have to SSH into the APs to change your password to meet the new requirements.
CCramer
Nov 18, 2019Initiate
stanbray
Nov 18, 2019Tutor
CCramer,
Thank you so much! I did have a period in my password. I was able to ssh in and update the password and log in. Just so that others will be able to easily do the same you need to do the following:
ssh in to the WAC720 as admin and use the current password.
Type the following commands:
set system password <password>
save-running
exit
Where <password> is the new password. Remember that the only special characters allowed (from another post) are: !@#$%^&*() and you need to have at least one number. If the password is rejected you get a cryptic error message stating the the value of your password is not a valid property.
Stan
