aam2babies
Apr 30, 2017Initiate
Unable to log into router G54/N150
I recently started having issues with my internet. First, my modem tx power was too high. Its been adjusted and it is still slightly too high, but we're working on it. I am able to get online anyway...
- May 01, 2017
Welcome to the community, aam2babies
I suggest that you factory reset the router.Did you try to use DHCP on the computer?
What's the IP address that the router will give to the computer?
ElaineM
May 01, 2017NETGEAR Employee Retired
