DarthYoda
Oct 02, 2022Aspirant
unable to log into the router configuration
I try logging into tbe rounterlogin.com and net address to change the IPV6 confiugration to fix the DNS error and all I get is the reset password screen everytime. Plaese advise how to get to the co...
Oct 02, 2022Guru - Experienced User
Are you resetting the password?
If you're not meeting the minimum requirements it doesn't change it and triggers the reset process.
minimum requirements:
at least 10 characters
1 upper case
1 lower case
1 special character
1 number
DarthYoda
Oct 04, 2022Aspirant
I have reset the password with the correct requirements, but keep getting the reset password screen everything I try to get into the login pages to get to the configration screen.
