rmasterj
May 02, 2022Follower
Unable to login and access AC1750 Smart WiFi Router, Model R6700v3
I am unable to login to my AC1750 Smart WiFi router. The power light is on but no other lights. Any thoughts?
May 02, 2022Guru - Experienced User
What color is the power light?
Did you try a factory reset? push and hold reset for 7-15 seconds while its powered on.
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
