ArigatoManga
Nov 30, 2020Follower
Unable to login to router WNR612 even after factory reset
Hi all, I'm unable to login to my router - WNR612v3 N150 even after factory reset. The username/password provided behind the router are - admin/password but when i try with those credentials ...
Nov 30, 2020Guru - Experienced User
When many factory reset, they just click the button. It needs to be pushed and held for 7-15 seconds while the device is powered on.
That gets you back to the defaults.
Also make sure you disable any password managers as they can sometimes overwrite the info you're putting in.
Might be time to check into an upgrade. That's an old single band N150 router that was slow when it was released 8 years ago. Unless you're on a pretty slow dsl connection, you might see decent performance improvements with an updated router.
