slackrl
May 16, 2019Luminary
Unable to Login to WNDR4500v2
Hello all:
Starting this thread after searching for this issue and found the link below for NightHawk Router.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/I-can-t-log-into-the-admin-of...
- May 18, 2019
Hello All
The Results are in!
Reset WNDR4500v2 Router
Still not acces after going through steps in manual
and this NetGeard Commuity link If you cannot login to your router
Bottom line: My trusty WNDR4500v2 Router gave up the ghost :smileysad:
It worked just find however would not let me access the admin.
Symptons it became more and more erratic in allowing login until ....no more.
Even after factory reset.
Solution: Tested with spare WNDR4500v3 Router, as soon as it was online I was in setting up
and backing up the config setting file.:smileylol:
It has Firmware Ver V1.0.0.32
Which was updated Dec 2019
It want's to update to a new version Ver V1.0.0.56
I beleive I will wait to and check out any complaints with the new version before upgrading.
Will be pickig up a new Router as a spare soon.
Good investment for me to have purchased a spare right after buying the original.
Thanks again for everyone's input.
Much appreciated
RSlack
V1.0.0.56 Firmware Version V1.0.0.32
antinode
May 16, 2019Guru
To what is the WNDR4500v2 connected?
> 192.168.1.1 (my normal entry point)
What's the IP address of the computer where you try this?
> [...] Nor any PC or tablet, smart phone, this is after Modem reset and
> restoral of backup modem configuration. [...]
A WNDR4500v2 is a router, not a "Modem". Do you have a modem
(connected to the WNDR4500v2)? What is it?
Are you dealing with wired or wireless connections to the WNDR4500v2?
(Wired would be simpler.)
> I will be testing another reset without reloading the backup config
I'd try that.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for
"Troubleshooting".
- slackrlMay 16, 2019Luminary
Hello antinode:
Thanks for you reply.
Re your questions;
Q. To what is the WNDR4500v2 connected?
Not sure of your question so here goes....
PC is Dell Laptop
Modem is Spectrun Arris Cable Modem DOCSIS 3.0.
Q. What's the IP address of the computer where you try this?
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
IPv4 Address. . . . . . . . . . . : 192.168.1.3
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1Q. A WNDR4500v2 is a router, not a "Modem". Do you have a modem
(connected to the WNDR4500v2)? What is it?My apologies and thanks for the correction I meant to say Router reset and backup config restoral.
Yes Spectrum Cable Modem Arris MODEL: TM1602A
Q. Are you dealing with wired or wireless connections to the WNDR4500v2?
(Wired would be simpler.)Wired to Lan port 1 of Router for this testing procedure.
"Troubleshooting".Already have done this. I will look in Troubleshooting "Cannot Login to Router"
RSlack
