KirkVS
Feb 05, 2016Follower
Unable to obtain IP address from WNDR4300v2 after setting as access point
I have to admit, this is my first time trying to extend my wireless range, and I'm confused by the whole access point concept. It seems like what I really want is a repeater, but that mode isn't ava...
- Feb 06, 2016
what you need is wireless repeating but i dont think this model supports that function. I suggest you buy an extender.
AP mode = main router (LAN port) > WAN port (router2) > clients (wired + wireless)
Wireless bridging = main router (wireless) > wireless (router2) > clients (wired ONLY)
Wireless repeating = main router (wireless)> wireless (router2) > clients (wired + wireless)
10bender
Mar 14, 2017Aspirant
The onboard software has repeater and base options, sure its not supported?
- ElaineMMar 16, 2017NETGEAR Employee Retired
10bender If you do get an option for Wireless repeating then you can use the wireless repeating feature. However, if you don't then there's no way to repeat the signal or extend the signal wirelessly.
Also, it will be indicated in the manual if it supports such feature.
