d4n1d4r
Mar 10, 2023Tutor
unable to obtain ip address on linux when wired to 6300v2 in AP mode
this is my setup: modem --> openwrt-router(no wifi) -- netgear R6300v2(AP mode) -- dual boot laptop. I have repurposed the r6300v2 running firmware V1.0.4.46_10.0.93 in AP mode and connected it to...
d4n1d4r
Mar 11, 2023Tutor
yes indeed the features disabled in ap mode does not specify that the lan dchp passthrough is disabled or is it?
how can it be the openwrt router if windows is able to get a dhcp address and on linux wifi can get a dhcp address it is jut the wired interface where the bootp packets do not even reach the router
do netgear disable lan dhcp passthrough in ap mode? that is not written in the doc...
leoyan
Mar 15, 2023Aspirant
Hi, I can confirm I have the same issue.
After I set my R6300v2 in AP mode, then any machine connected with LAN port in R6300v2 cannot get dynamic IP address from the connected OpenWRT router.
