PapaK
May 15, 2022Initiate
unable to sign into Nighthawk app for R6400v2
I'm unable to sign into my Netgear account from the app on my phone. I can use the same user name and password and log in on line with no problem. I'm looking to update my firmware Thanks
- May 15, 2022
Which "Netgear account" is that? You donlt need any "account" to use or manage a router.
Login to what? Nighthawk app? The router? The wifi? Something else?
I can use the same user name and password and log in on line with no problem.Login to what?
I'm looking to update my firmwareThis is the safest and most reliable way to do that:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
michaelkenward
May 15, 2022Guru - Experienced User
Login to what?
PapaK
May 16, 2022Initiate
Thanks for the instructions. I realized as you asked more questions that I was confusing my Netgear account with my router sign in and after recovering my router sign in and connecting with an ethernet cable, I was able to update my firmware. Thanks (next time I'll be more specific 🙂 )
- michaelkenwardMay 16, 2022Guru - Experienced User
Netgear has just too many logins and passwords. No surprise that people get confused.
