jack316
Feb 25, 2016Aspirant
Unable to start Netgear WNR614 N300 Wifi Router
From past few days i am not able to start my router. Even after giving a power supply, its not working. Not able to see any green Led light on the device. Any help would be appreciated.
- Retired_MemberFeb 25, 2016
Check power adapter with a volt meter if no output replace power pack if output is as stated on power pack label make sure the connection is secure, if secure and power pack checks out and still no start replace router.
Retired_Member
Feb 25, 2016Check power adapter with a volt meter if no output replace power pack if output is as stated on power pack label make sure the connection is secure, if secure and power pack checks out and still no start replace router.
- jack316Feb 25, 2016Aspirant
Thanks for the solution.
You're welcome!
