kagetora13
Dec 19, 2015Aspirant
Unable to upgrade firmware on WNR2000V5 from V1.0.0.20 to V1.0.0.34
I've read through the forms on the on going issues people are facing trying to upgrade their firmware on WNR2000V5 to V1.0.0.34. Presently I am trying to upgrade WNR2000V5 via the "WNR2000v5-V1.0...
- Jan 12, 2016
I would suggest for you to contact support.
TheEther
Dec 19, 2015Guru
I looked on Netgear's support website and they don't offer 1.0.0.20 for the WNR2000V5. Are you sure that that's the model you have? Can look at the model number printed on the sticker?
kagetora13
Dec 22, 2015Aspirant
Thank you for your response. I took a screenshot after logging into the router.
- TheEtherDec 22, 2015Guru
Well, that's quite interesting. Did you take a look at the sticker? Does it also say WNR2000V5?
- kagetora13Dec 23, 2015Aspirant
The bottom has the MAC address and serial number which I believe i provided in the original post
- TheEtherDec 23, 2015Guru
Thanks for obliging. You definitely have a WNR2000V5. :smileyhappy:
It's a puzzle as to why you can't upgrade the firmware. What are you using to unzip the download? Perhaps you can try a different unzipper?
