jmclh
Jan 23, 2016Aspirant
Unable to use Airdrop on my MacBook Pro 13in Retina 2014 since using R6200 router
Router firmware V1.1.00.14 .Airdrop works using old Plusnet Technicolor router. Interestingly the Airdrop still works between iPhone and iPad on both routers.Tried emailing Netgear support who at ini...
- Jan 25, 2016
Hi @jmclh,
I have sent you a message. Please check your inbox.
Dexter
Community Team
DexterJB
Jan 23, 2016NETGEAR Moderator
Hi @jmclh,
1. Can the MacBook Pro ping the other devices (iPhone and iPad)?
2. Has it worked before?
3. Have you tried turning off the firewall on the MacBook Pro?
Dexter
Community Team
jmclh
Jan 24, 2016Aspirant
Thank you for your response,
I have tried turning off the Firewall on the Macbook - no improvement.
It has not worked ever- except on the old (non Netgear) router
I tried pingiing the iPhone with this response
^C
--- 192.168.0.5 ping statistics ---
32 packets transmitted, 29 packets received, 9.4% packet loss
round-trip min/avg/max/stddev = 29.648/137.042/312.671/79.414 ms
Jonathans-MacBook-Pro:~ Jonathan$
Does that give any clues ?
Thanks
- DexterJBJan 24, 2016NETGEAR Moderator
Hi @jmclh,
Is the model number of your router R6200v2? If yes, please try updating the firmware to the latest version (1.0.3.10) then reset and reconfigure the router. You may refer to the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
- jmclhJan 25, 2016Aspirant
Hi DexterJB,
I think my model is V1 - using Netgear Genie indicates that the firmware is V1.1.00.14 and this is the latest version. Should I still do a factory reset ?
- DexterJBJan 25, 2016NETGEAR Moderator
Hi @jmclh,
Dexter
Community Team
