jmclh
Jan 23, 2016Aspirant
Unable to use Airdrop on my MacBook Pro 13in Retina 2014 since using R6200 router
Router firmware V1.1.00.14 .Airdrop works using old Plusnet Technicolor router. Interestingly the Airdrop still works between iPhone and iPad on both routers.Tried emailing Netgear support who at ini...
- Jan 25, 2016
Hi @jmclh,
I have sent you a message. Please check your inbox.
Dexter
Community Team
jmclh
Jan 25, 2016Aspirant
Hi DexterJB,
I think my model is V1 - using Netgear Genie indicates that the firmware is V1.1.00.14 and this is the latest version. Should I still do a factory reset ?
DexterJB
Jan 25, 2016NETGEAR Moderator
Hi @jmclh,
Dexter
Community Team
