extrememetal
Nov 18, 2015Aspirant
Unable to use Quality of service on my Router.
I would like to limit other devices' internet speed via my WNR614 router through my laptop. The existing QoS tab in Advanced>Setup, does not show (image below) this screen. Please help.only t...
- Dec 07, 2015
I told that the sample image is what I want.
Please stop criticizing people if you are wrong.I can prove it also.
I wanted to enable QoS on WNR614
My netgear page (routerlogin.net) doesn't have those many lines as the pic I posted has.
I posted because I wanted that menu
So due to the QoS not being available I posted it online.
I don't wear Specs or glasses.
But you are a BLIND, ILLITERATE AND NOSEY SCUMBAG WHO DOES NOT MIND HIS OWN BUSINESS.
I WANTED SERIOUS HELP.
I AGAIN REPEAT IT IN SIMPLE WORDS.
THE PIC IS WHAT I WANT (THOSE MANY OPTIONS)
CAN I GET THEM
IF NOT PLEASE SHUT UP YOUR MOUTHS
NOW UNDERSTOOD WHY I WORTE IN SUCH A BIG FONT SIZE
EVEN THEN YOU DID NOT GET THE QUESTION.
AND WERE TRYING TO ACT SMART.
IT WILL BE BETTER IF YOU KEEP YOUR SMARTNESS TO YOURSELF.
AND IF YOU CAN'T HELP OTHERS, KEEP YOUR NOSE OFF THE ENTIRE INTERNET.
Retired_Member
Nov 19, 2015Do you wear glasses? Try enabling QOS
- extrememetalDec 07, 2015Aspirant
CAN I GET THEM
- Retired_MemberDec 08, 2015
When posting a link you might mention it. The link was not underlined and due to your 1st grade chalkboard size fonts and red color the blue fonts did not stand out to me as they would had if you used the traditional size and color, it wasn't clear to me that the blue text was actually a link rather just another attempt to get attention.
Best I can tell from your child like communications skills you want QOS like the WNDR4700 has on a Wnr614 is that correct? I'm happy, No it makes my day to inform you it's not available for that model.
Lastly you POS I took the time to read your pathetic post and you have the nerve to respond this way. Not one other person even commented or tried to help.
- extrememetalDec 09, 2015Aspirant
If you dont want to answer don't answer.
Don't show your smartness.
In spite of me writing so boldly(because I thought it would be a bit difficult to understand) you did not get me.
And on top of that you are blaming me, pretty sad.
I just asked for help, but what can I do if you don't understand. I can, at the most explain you.
talking about link, you should have replied me to give a link, to which I would have told, its in blue.
Sad but true, you are not at all in the mood of helping.
People like you only cause humiliation to others by showing your non-existent smartness
- ElaineMDec 08, 2015NETGEAR Employee Retired
The router model you have does not support such feature.
You may want to look at other routers that has QoS capability.
duplicate
