extrememetal's avatar
extrememetal
Unable to use Quality of service on my Router.
I would like to limit other devices' internet speed via my WNR614 router through my laptop.   The existing QoS tab in Advanced>Setup, does not show (image below) this screen.   Please help.only t...
  • extrememetal's avatar
    extrememetal
    Dec 07, 2015
    I told that the sample image is what I want.
    Please stop criticizing people if you are wrong.
    I can prove it also.
    I wanted to enable QoS on WNR614
    My netgear page (routerlogin.net) doesn't have those many lines as the pic I posted has.
    I posted because I wanted that menu
    So due to the QoS not being available I posted it online.
    I don't wear Specs or glasses.
    But you are a BLIND,  ILLITERATE AND NOSEY SCUMBAG WHO DOES NOT MIND HIS OWN BUSINESS.
    I WANTED SERIOUS HELP.
    I AGAIN REPEAT IT IN SIMPLE WORDS.
    THE PIC IS WHAT I WANT (THOSE MANY OPTIONS)
    CAN I GET THEM
    IF NOT PLEASE SHUT UP YOUR MOUTHS
    NOW UNDERSTOOD WHY I WORTE IN SUCH A BIG FONT SIZE
    EVEN THEN YOU DID NOT GET THE QUESTION.
    AND WERE TRYING TO ACT SMART.
    IT WILL BE BETTER IF YOU KEEP YOUR SMARTNESS TO YOURSELF.
    AND IF YOU CAN'T HELP OTHERS, KEEP YOUR NOSE OFF THE ENTIRE INTERNET.
