naivebelle's avatar
naivebelle
Unsecured Wi-FI Connection warning
This week, I suddenly started getting an "Unsecured Wi-Fi Connection" warning (from Trend Micro Maximum Security) on my Samsung Galaxy Note 9. When I opened Chrome (on my PC) and went to the IP address for my router, it did a firmware update but I'm still getting the not secure warning on my phone. Full warning message:
Using banking or shopping apps while connect to (network name) could put your personal data at risk. Switch to a different Wi-Fi network or use a 3G/4G connection instead.
Switch Networks
Close
  1. Why am I suddenly getting this warning?
  2. What do I need to do (if anything)?
I'm using:
  • NETGEAR WNR-2000v2
  • WEP128
  • WEP Key 26 numbers and letters
  • Firmware (updated today but can't figure out what version it is)
  • Chrome v. 74.0.3729.108 (Official Build) (64-bit)
  • Windows 10 Home 64-bit
  • Samsung Galaxy Note 9 with Android 9 (all updates installed)
  • Trend Micro Maximum Security (on both PC and phone)
Thanks for any assistance you can provide!
  • > [...] I suddenly started getting an "Unsecured Wi-Fi Connection"
    > warning (from Trend Micro Maximum Security) [...]
       Ask Trend Micro?
    >    o WEP128
       WEP has been vulnerable/obsolete for some years, now.  Perhaps "Trend
    Micro Maximum Security" now classifies it as "Unsecured".
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Look for "Changing Wireless
    Security Settings".  Select something with "WPA" in it.  I'd probably
    choose "WPA2-PSK [AES]".
       Then run around to all your wireless client devices, and reconfigure
    them to use the new scheme.  To avoid confusion, it might make some
    sense to specify a new/different SSID ("wireless network name") when you
    change the encryption scheme from WEP to WPA[2].  Then you'd simply be
    adding a new wireless network on each client device.
    > o Firmware (updated today but can't figure out what version it is)
       On a less obsolete router model, it's normally displayed on almost
    every page you'd get from its management web site ("routerlogin.net", or
    whatever).  On your antique, it seems to be under Maintenance > Router
    Status.  Look for "firmware" in the User Manual.
       Ask Trend Micro?
    >    o WEP128
    • naivebelle's avatar
      naivebelle
      Thanks antinode! A couple more questions:
      1. Do you recommend that I get a new router?
      2. If so, any recommendations?
      • antinode's avatar
        antinode
        Guru
           Not if your antique does the job.  A newer model would likely have
        more features, and be capable of higher wireless-network speeds, but I
        know nothing about your Internet service or your client devices, which
        means that I don't know where your bottleneck is now, so I can't
        guarantee that a newer/faster router would make any noticable change.
           Nope.  Depends on your environment/requirements.  I'd definitely look
        beyond Netgear, however.
