JJ2022's avatar
JJ2022
Update Firmware for R6220 won't work
Background
Using NetGear Router R6220
Todya the current version is V1.1.0.50_1.0.1
Goal:
Upgrade the firmware.
Problem:
I tried to use the routerlogin.net > Administration > firmware update > Check
but it doesn't provide any download or upgrade.
I also have tried to dowload the file at https://www.netgear.com/support/product/R6220.aspx and then upload it at routerlogin.net but It doeesn't work. It won't upgrade
I also hav tried to use the app https://nighthawk-app.com/ but it only tells me to go to routerlogin.net abd update it.
What should I do?
Thank you!
    • JJ2022's avatar
      JJ2022
      "When you're trying to manually update it, what error do you get? "
      I don't get any error message.
      I behavethat it would be working but in the end, it is the same result without any changing effect. Consider it the same when you do windows update.
      "Did you unzip the file prior to uploading it to the router? "
      Yes, I did unzip the file and then uploaded at web browser.
      • michaelkenward's avatar
        michaelkenward
        One thing you can try is to "factory reset" the router before you apply the update.
        But before you do that, create a backup of your current configuration.
        So:
        • backup settings
        • reset router
        • apply update
        Then, if the update works, you can either reconfigure the router – if it isn't too complicated – or you can restore the backup.
        Be warned that retiring the backup can cause problems. It just may be that the configuration has errors that will arise from the dead, zombie like, and cause problems. Just keep your eye open for that.
