McKenna25
Aug 13, 2020Aspirant
Update Firmware unknown error -1 D6400 model
HI, Am trying to update modem version V1.0.0.56_1.0.56 after downloading update - message is unknown error -1. If this because to many updates in between. Wonder if anyone can help, please. Chris...
- Aug 15, 2020
McKenna25 wrote:
Wondered if the update was to advanced the current one on the modem is the one l listed.
That has certainly been the case in the past.
Try something somewhere in the middle – between your version and the latest – and see if that works. Then work your way up. Not one step at a time, once you have got one update to stick, try the newest. You just need to find the one that unblocks the process.
You could also try a factory reset before and after the upgrade. Netgear also sometimes recommends a modem/router reboot before an update.
This loses your settings – you have to reconfigure the modem/router – but a large leap in versions probably needs that anyway.
McKenna25
Aug 14, 2020Aspirant
Thank you for the info
McKenna25
The error came up when trying to install new update. Download fine when tries to update came up with unknown error -1.
did follow what you said and tried but no help.
Chris
