MuktiMom's avatar
MuktiMom
Update V1.0.0.78.img is corrupted when I try to open it.
I got the Netgear notice to update my firmware.  The routerlogin.net link in the email doesn't work in Chrome.  I used a bookmarked link to check my firmware and it is out of date.  I clicked Firmwar...
  • michaelkenward's avatar
    Jan 08, 2022
    This is a bit confusing.
    Visit the support pages:
    Support | NETGEAR
    That section will have a library of firmware for your device.
    The file was a cd file, and I was asked if I want to burn it.
    It was an .img file,  not to be confused with an "image" of a CD. That file has nothing to do with CDs. It is just the file extension that Netgear chose for its firmware files. (Some firmware has he equally confusing .chk extension.)  You do not "open" the .img file, you tell your router to "load" is.
    The instructions are here:
    How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
    The manual for your device also explains what to do.
    The support pages also have documentation for your hardware.
    Check the section in the manual on updating the firmware.
    I'm using UnzipPro to extract the file because Windows refuses to extract it..
    Something odd is happening in Windows at your end. There is nothing wrong with the zipped firmware file. It happily responds to a "right click > Open in Windows Explorer" operation.
