wally3333
Mar 19, 2023Follower
update Wireless Router (WNR1000v3)
How do i update my router above i can not use the app it is not for my unit . thank you very much
- Mar 20, 2023
You want to update the firmware on your WNR1000v3?
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Be warned that this device first appeared in 2010, based on an original router from 2009. It has slow WiFi. (They don't come much slower than N150.) The Ethernet is back from the era of 100 Mbps.
So don't expect much.
The latest firmware dates back to July 2020.
michaelkenward
Mar 20, 2023Guru - Experienced User
