fcs659
Jun 03, 2018Aspirant
upgrade n900
I read that I am supposed to reset my router an check for upgrades. Now that I have spent over 30 minutes trying to figure out how...is there anyone out there that can provide SIMPLE CLEAR clear inst...
- Jun 08, 2018
Yes just disconnect from power and back on was all that they were asking people to do. By the way, I didn't see the n900 routers on the list of routers that were supposedly affected but always good to make sure by power cycling it in case.
fcs659
Jun 08, 2018Aspirant
wcalifas831 wrote:
If you're talking about that fbi vnp malware that was on the news all they required you to do is to power cycle your router not a hard reset.
Thanks, I am assuming "power cycle your router" means to turn it off and on. Will do.
wcalifas831
Jun 08, 2018Prodigy
