JeeGee
Mar 17, 2021Follower
Upgrade old : Firmware Version V1.0.0.2_11.0.47 to V1.2.2.28
Hi,
When logged in into the router, WNR3500v2,
i can't find the "Upgrade Assistant" or any entry to install the newer Firmware.
How to upgrade now, i see just "Basic Settings"
Under "Router Status" i find old : Firmware Version V1.0.0.2_11.0.47
On Netgear-site, newest : Firmware Version V1.2.2.28 (All regions except North America)
J.
1 Reply
You should be able to upgrade manually. Download the firmware and extract it.
Then its under maintenance on the main menu and then select router upgrade.
From there click browse and use the extracted firmware.
The manual goes over it. find the firmware and the manual here:
https://www.netgear.com/support/product/WNR3500v2.aspx
