mschool
Oct 31, 2016Aspirant
Upgrade options?
Hello. I have been using the WNDR3700 for years, but recently notice that I have more frequent IP adress conflicts with the number of new devices on my home network. My SF flat has thick lathe and pl...
- Retired_MemberNov 01, 2016
Ip conflicts are usually the result of a misconfigured device, while your last post stated 1 AP it does appear you have 1 AP and 2 routers. Two routers if Not configured correctly will cause IP conflicts.
Maybe someone else can help.
Good Luck I'm done
mschool
Nov 01, 2016Aspirant
It's one AP, and the IP addressed is fixed. Here are notes from the previous router and AP. I have 24 devices on my network. The router is the DHCP server.
> WPN824
> Router IP 192.168.1.1
> IP range 192.168.1.2 ~ 192.168.1.50
> sbunet 255.255.255.0
> WPN802 should be
> IP address192.168.1.51
> subnet 255.255.255.0
> gateway 192.168.1.1
> dns uses dns listed under router status, internet port DNS
Retired_Member
Nov 01, 2016Ip conflicts are usually the result of a misconfigured device, while your last post stated 1 AP it does appear you have 1 AP and 2 routers. Two routers if Not configured correctly will cause IP conflicts.
Good Luck I'm done
