ylb's avatar
ylb
Upgrade to V1.0.1.12_1.0.58 broke 2.4Gz
The upgrade to firmware version V1.0.1.12_1.0.58 has halted functionality of the 2.4GHz spectrum on my router.  I've rebooted the router, stopped/started 2.4GHz SSID, reset the password for 2.4GHz, m...
  • ylb's avatar
    Sep 08, 2017
    I found a solution, but this should be logged as a bug for firmware version V1.0.1.12_1.0.58.
    The Guest network for the 2.4GHz must be enabled for the non-guest 2.4GHz network to accept connections after upgrading to this version of firmware.
    There is no reason why the guest network should be required to be enabled, but funtionally it is required in this version of firmware.
    -ylb
