eagetal96
Jan 25, 2017Aspirant
Upgraded Internet Speed and Netgear600 router won't support it....I think.
I have a surfboard SB6183 Modem and the N600 router. I previously had comast blast 75/10 and was getting these speeds hardwired with my imac. I upgraded to 150/25 and the speeds went to 90/22. When w...
- Jan 25, 2017
eagetal96 wrote:
Thanks for the quick reply, it is the WNDR3400V3 model.
Yes, that one is also fast ethernet, and not gigabit. http://www.downloads.netgear.com/files/GDC/datasheet/en/WNDR3400v3.pdf?cid=wmt_netgear_organic
So you'll need to upgrade the router to take advantage of the your faster internet speeds.
michaelkenward
Jan 25, 2017Guru - Experienced User
Which N600 are you talking about? That is not a Netgear model number.
Here's a clue on where to look:
If it is a really old box, then the LAN ports will be 100 Mbps. Newer models are 1000Mbps.
If it is a 100 Mbps router, such as the JNDR3000 and WNDR3400v2, then you are stuffed. There are no settings that you can tweak to make it go faster.
eagetal96
- StephenBJan 25, 2017Guru - Experienced User
