eagetal96
Jan 25, 2017Aspirant
Upgraded Internet Speed and Netgear600 router won't support it....I think.
I have a surfboard SB6183 Modem and the N600 router. I previously had comast blast 75/10 and was getting these speeds hardwired with my imac. I upgraded to 150/25 and the speeds went to 90/22. When w...
- Jan 25, 2017
eagetal96 wrote:
Thanks for the quick reply, it is the WNDR3400V3 model.
Yes, that one is also fast ethernet, and not gigabit. http://www.downloads.netgear.com/files/GDC/datasheet/en/WNDR3400v3.pdf?cid=wmt_netgear_organic
So you'll need to upgrade the router to take advantage of the your faster internet speeds.
eagetal96
Ok, thank you!
- William10aJan 25, 2017Master
Almost any of new gigia port Netgear routers will work the r6400 of r7000 should just if the wndr3400v3 covered the with wifi. The my slow for now but keep it as you make a repeater or access point out of it to cover areas where not cover now.
- michaelkenwardJan 25, 2017Guru - Experienced User
William10a wrote:The my slow for now but keep it as you make a repeater or access point out of it to cover areas where not cover now.
Hard to understand that. EFL?
