woodbury
Jun 25, 2017Aspirant
Upgrading Firmware
I've been able to download the current firmware for the router. But I'm not able to log into http://www.routerlogin.net/ to complete the upgrade. I'm not remembering either the correct username o...
- Jun 26, 2017
Thank you. No longer a problem. Simply needed the username and password in order to log into router.net for my wifi router. Found that it was "admin" and "password"
woodbury
Jun 26, 2017Aspirant
michaelkenward
Jun 26, 2017Guru - Experienced User
Yup.Mark your answer as the solution and you may benefit people who turn up here with the same issue.
For the benefit of others in the same boat, that's straight from the manual and the label on the back of the device.
If you change it to something you have forgotten, you can get it back by doing a factory reset using the hole in the back of the device.
- woodburyJun 26, 2017Aspirant
I tried the UN on the back of the Wifi Router... it did not work...
but.... the default mentioned aboved did.
Thanks.
