OrganicApple8
May 19, 2018Tutor
UPNP no longer works on R6250 firmware V1.0.4.26
UPNP no longer works on my R6250 since I updated to fw V1.0.4.26 last month. I have performed a factory reset and multiple reboots to no avail. Which led me to believe this is a fw issue that disable...
- May 19, 2018
Just downgraded to fw 1.0.4.16 and UPNP functions again. Portmapping now lists open ports/ip addresses, did a test on my PS3 and shows upnp available. I can confirm this is an issue with the latest fw and needs to be fixed.
michaelkenward
May 19, 2018Guru - Experienced User
OrganicApple8 wrote:
Another user here has encountered a similar problem on their Netgear Nighthawk with the latest fw disabling upnp and said Netgear devs are working on the fix.
In the meantime, you can see if UPnP will return if you roll back to the previous firmware.
OrganicApple8
May 19, 2018Tutor
