m_schmitt
Sep 05, 2018Initiate
UPnP still broken on R6400
UPnP stopped working on the R6400 as of a recent firmware upgrade; I'm thinking it was 1.0.1.42 in June.
1.0.1.44 is now out, and UPnP still doesn't work.
Am I correct in assuming that th...
- Jan 05, 2019
UPnP is fixed by R6400 firmware version 1.0.1.46.
I presume this doesn't open exposure to WAN-side UPnP attacks.
NMCEngineer
Sep 14, 2018Aspirant
I have the same issue. UPnP does not work after the firmware upgrade. I had to use port forwarding to access my IP cameras. Also, the camera dns names no longer work. I have to now use the actual IP address of the router to access the cameras.
- NMCEngineerSep 14, 2018Aspirant
My firmware version is V1.0.1.42_1.0.28. I noticed there is a fix for the R6700. Any chance getting an update forR6400?
- antinodeSep 14, 2018Guru
> [...] the camera dns names no longer work. I have to now use the
What are these "the camera dns names"? Are you saying that some DDNS
feature is not working, or what?
Does reverting to an older firmware version help?- NMCEngineerSep 14, 2018Aspirant
I could not find the previous versions of the firmware. Do you have a link?
Amcrest is the DNS server. This no longer works with the latest firmware update.
