eldiener
Mar 24, 2017Tutor
USB Control Center connection but no printer output
I have a printer connected to the USB port on my WNDR3800 router. I installed the ReadySharePrinter_setup_v1.36 on Windows 8.1 and the Netgear USB control center found my printer off of my router and...
- Mar 25, 2017
After reinstalling the HP printer driver the printer is now working.
michaelkenward
Mar 25, 2017Guru - Experienced User
Which printer is this?
Have you been through all of the steps laid out in the manual?
>>>> WNDR3800 | Product | Support | NETGEAR <<<<
See page 51.
Remember, as the manual says you have to install the USB printer driver software on each computer that will share the printer.
- eldienerMar 25, 2017Tutor
- michaelkenwardMar 25, 2017Guru - Experienced User
Well done. Mark your solution as "Solved" and it could help anyone who turns up later with the same question.
How do I mark it as "Solved" ?
