Cmmiles
Feb 25, 2018Aspirant
USB drive not appearing on R6300
I'm trying to get USB drive attached to our R6300 router. The USB indicator light on the router won't even light up. I've tried three USB drives already. Does anyone know how to get this thing to rec...
- Mar 04, 2018
Hi Cmmiles,
What is the file format for the storage devices? Please make sure it is among one of the supported formats. The link below may help.
http://kb.netgear.com/app/answers/detail/a_id/24059
Dexter
Community Team
DexterJB
Feb 25, 2018NETGEAR Moderator
Hi Cmmiles,
1. Has it worked before?
2. Does the issue persist on both the USB ports (2.0 at the back and 3.0 o the side)?
3. To confirm, do the USB storage devices work when connected straight to a computer?
4. Have you tried resetting the router?
5. Have you tried checking the router UI if the USB device/s appear under ReadySHARE?
6. You can try updating to a later firmware version (1.0.2.80) and do a factory reset to check if the issue persists.
Dexter
Community Team
- CmmilesFeb 28, 2018Aspirant
Thanks for the response and help!
- No, this is the first time I've tried connecting a drive
- Neither USB port would recognize a drive was there.
- Yes, each works on a desktop computer in the house
- Yes
- The UI like in the mobile app?
- I will try that now and let you know how that goes.
Dexter
Community Team
- DexterJBMar 01, 2018NETGEAR Moderator
- CmmilesMar 03, 2018Aspirant
Hmmmm, I updated the firmware and added the external back to it and still no drive.
- DexterJBMar 04, 2018NETGEAR Moderator
Hi Cmmiles,
Dexter
Community Team
