jonb1
Aug 21, 2017Aspirant
usb drive on R6250 cannot see on ex6100 extender
i have a R6250 wifi router with a usb drive connected to it which i can see and use when connected wireless to router but when i connect through ex6100 wifi range extender i cannot see or connect to ...
- Sep 07, 2017
i have solved this issue.
When you set up EX6100 as extender and you need access to whatever you have plugged in USB you must select Home (private network)
Also for information you can use 4 port USB hub on a Netgear Router R6250
DexterJB
Aug 28, 2017NETGEAR Moderator
Hi jonb1,
1. What is the firmware version of the router and the extender?
2. Can your devices ping the router when connected to the extender?
3. Is the extender set to Access Point mode or Extender mode?
Dexter
Community Team
jonb1
Aug 28, 2017Aspirant
Here is the information you requested
Hardware Version: Extender EX6100
Firmware Version: V1.0.2.16_1.1.130
Hardware Version Router R6250
Firmware Version V1.0.4.12_10.1.15
Yes can ping 192.168.1.1 average 1ms through extender
Set extender mode
