jonb1's avatar
jonb1
usb drive on R6250 cannot see on ex6100 extender
i have a R6250 wifi router with a usb drive connected to it which i can see and use when connected wireless to router but when i connect through ex6100 wifi range extender i cannot see or connect to ...
  • jonb1's avatar
    jonb1
    Sep 07, 2017
    i have solved this issue.
    When you set up EX6100 as extender and you need access to whatever you have plugged in USB you must select Home (private network)
    Also for information you can use 4 port USB hub on a Netgear Router R6250
