Ankenyike's avatar
Ankenyike
use a hotspot as the internet source to the router
I want to use an Android phone hotspot as the internet connection TO the router, and then will connect via ethernet cable, a weather station.  The weather station needs to be hard wired to a router, ...
  • microchip8's avatar
    microchip8
    Jun 24, 2016
    Bridge mode can be done on most (recent) NETGEAR routers. you don't need additional equipment for that. I recommend AC1900-class routers like the R7000 which are best bang for buck and performance. don't stare yourself at the numbers of newer routers as they won't magically increase your range or so. And for the throughput, you'd need a compatible wifi card for that
