JohnCNA
Jan 03, 2021Aspirant
Use N600 in AP mode as NAS
I have a WNDR3400v3 (N600) that I'm no longer using. I was thinking of setting it up in AP mode and connecting a USB hard drive to it so I can access the drive over the network via ReadyShare. W...
- Jan 04, 2021
OK - Thanks for the reply.
Got it all set up now as an access point only and my USB drive is accessible from any other computer or phone on my home network.
antinode
Jan 03, 2021Guru
> If I set it up as an AP point, [...]
Access Point point? (See: http://antinode.info/complaints/aer.html )
You found "AP Mode" in the WNDR3400v3 User Manual?
> [...] will I be able to access the attached USB hard drive from other
> computers in the house? Or can that only be done if it's functioning as
> the main router?
I'd expect it to work as well either way, but when configured as a
wireless access point, it'll have some new/different LAN IP address, and
any "routerlogin" names might not work, so I'd expect you to need to use
its (new/different LAN) IP address to access the serverd storage.
Something like an "Attached Devices" or "DHCP Clients" (or similar)
report from your (unspecified) main router should tell you that.
And you'd probably want to reserve an address for the
WNDR3400v3-as-WAP on the (DHCP server on the) main router, so that
it won't go wandering around every time you restart some gizmo.
- JohnCNAJan 04, 2021Aspirant
