RecordThieves
Sep 27, 2023Aspirant
use router without wifi...
OK, this is unique, but I would like to clarify first that I am using this router WITHOUT internet. I don't need it to be connected to the Internet, and I won't ever use it for the Internet. This...
michaelkenward
Sep 27, 2023Guru - Experienced User
Your subject says:
Then you say:
RecordThieves wrote:
Every device that tries to get on the Wi-Fi network to establish a connection gets prompted with a popup window asking to change the network's password.
Did you mean "Use router without Internet..."?
- RecordThievesSep 27, 2023Aspirant
yes
- michaelkenwardSep 27, 2023Guru - Experienced User
Do you still want to have local wifi?
as previously stated, it needs NO internet connection. the WIFI connection works fine for us to connect to, BUT each time we connect to the router on ANY device... it asks us to change the WIFI password. all I need is for any / all of our devices to connect to the router and NOT have it give us a pop-up that tries to make us change the password.
how do we stop that prompt?
