Jno2's avatar
Jno2
Tutor
Oct 24, 2021
Use WNDR3700v3 as AP
I need to set up my 3700v3 as an access point. I see several youtube videos... but not specific for this model and they suggest different things. Please HELP!
Thanks.
  • disable dhcp on it on the wan, and change the IP to something like 192.168.1.253
  • I saw the link for setting this up in the suggestions for this.  It talks about enabling the AP, which I've tried. Then I'm told I need to change IP addresses. I tried that and scrambled everything to the extent I  couldn't get back in... then had to reset and start over. HELP!
    • wcalifas's avatar
      wcalifas
      Prodigy
