eddy10957
Aug 24, 2021Follower
Used device bought on Amazon registered to another Email
Hi i just bought this used router/access point on Amazon (WAC 124), wanted to register it in my account in order to have the full control of my device and set up it, but unluckly I can't because it'...
TheRealkNoCKs
Jan 05, 2022Aspirant
I have the same problem. let me know if you got it fixed
wcalifas
Jan 05, 2022Prodigy
Why don't you juse do a hard reset on the access point and it will go back to factory default. No need to register it to make it work. Press the reset button for 30 seconds, not sure of that model but you might need a paper clip to press the reset button for 30 seconds.
- wcalifasJan 05, 2022Prodigy
On top of that once you reset it it will ask you some questions for your security (i.e. what's the name of your oldest sister or youngest sister, something to that effect), and then you'll be able to change any settings on the router.
- TheRealkNoCKsJan 05, 2022AspirantNegative, I just did all that. I just bought it from Amazon, I can't put on geo locate or bandwidth moderator with this serial number being on another account.
- michaelkenwardJan 06, 2022Guru - Experienced User
TheRealkNoCKs wrote:
Negative, I just did all that. I just bought it from Amazon, I can't put on geo locate or bandwidth moderator with this serial number being on another account.This is an old and long runnig saga. There used to be regular messages about stuff from Amazon.
Try this:
NETGEAR Product Registration FAQ | Answer | NETGEAR SupportYou have a couple of options, try to find a local contact number (it may be well hidden) or send a private message to one of the Netgear moderators here.
If you are lucky, maybe @ChristineT will step in.
They may ask you to send them a serial number and the email address you have registered with MyNetgear.
Unfortunately, while that clears previous settings it does not break the link between the serial number and things like the cloud registration used for Anywhere Access, for example.
